ThunderSquirrel
- 2
- 8
- Aurora, CO
Truck started making some bad noise when slowing down. A low grumble/grind, coming from the rear.
Had someone drive while I rode in the back to listen better, and it appears to be coming mainly from the right rear.
I am thinking that I am losing a bearing in my hub, considering there is no noise when the truck is under power.
Hoping it isn't my diff. The diff looked nearly new when the truck showed up, and was a 242 on a m998A0, so I assumed it was replaced.
Are there any other things I should check? Halfshafts and CVs seem tight, boots are brand new and no wiggle.
Going to pull the wheel off after work and see if I can hear anything while spinning the spindle.
Thanks,
Thanks,
