Jimc
- 1
- 18
- Mullica, nj
So what is the deal with these noise filters attached to the facet pumps? Are they needed? Has anyone removed them to see if there was any difference and if so what happened?
You can do that. I chose 50 because it's nearly double the normal voltage at the regulator output and will work fine for many years. A capacitor is a charge storage device, sort of like a mini-battery, but without a fixed terminal voltage, so you're right that whatever voltage if applied to it is what it will see. Its voltage rating is the maximum you should apply to it.i hear ya on that. since the original one is 75v i looked at the one you have posted the link to and they do make it in 100v version instead of 50. i assume that would probably be more within spec and give a little extra headroom?? if im not mistaken a cap is only going to put out what goes into it voltage wise.
Had the same problem with an MEP2 a few months ago. Wire broken off near the end of the capacitor. Scraped away some material IWO the "nub" and soldered a new wire to the nub to allow connection to the TB. Unit's been working ever since....Hmm, ok jerry thanks. Mine is kinda destroyed. Wires are just solid leads and they broke off right at the tube. Do you have one if i need it?
