dieselolds
- 0
- 0
- Norway
If the oil gets to thick to flow in the filter, maybe you need even thinner oil LOL
The Norwegian Dodge WC manual tells you to use 10W oil down to -20C and from -20C to -35C you have to mix the oil with diesel or gas. Below -35C you have to remove the oil filter element.
Non detergent oil leaves dirt everywhere in the engine and wears it out.
The Norwegian army did mount a courtain in front of the radiator to keep the heat inside the engine compartment and not blow right out.
John
The Norwegian Dodge WC manual tells you to use 10W oil down to -20C and from -20C to -35C you have to mix the oil with diesel or gas. Below -35C you have to remove the oil filter element.Non detergent oil leaves dirt everywhere in the engine and wears it out.
John
