- 538
- 379
- 63
- Waco Texas
Has the supply dried up, or is my search-fu just weak?
Steel Soldiers now has an offical calendar available, read more about it at: Steel Soldiers 2021 calendar
The armored trucks that are being demilled the armor wasn't added on. It was the whole door. So it gets the doors removed as the processWhy no doors?
There are several types of armor kits for the MTVR. Your truck had an APK kit more than likely, also called an MAS. There are other types such as the ECP system which uses a different door entirely.Huh?
Ours was an AMK23 (built with armor, not armor added on), and ours came with doors...and they didn't remove all the armor, so we've been pulling it out as needed...
That seems as if the answer should be pretty obvious? Do you see any on GP? No? Then there are none currently up for auction...So...back to my original question- are there currently none up for auction, or what?
