Now I Don't Know if my Cab is even a Gasser Cab.
Barrman
2,231
Giddings, Texas
PTO output shaft differences, pto drive shaft differences, airpack/master vent line routing, fuel line routing and fuel tanks are a few more things I thought of while heating up my lunch.
Barrman
2,231
Giddings, Texas
Yep, greasable trunions, oil fill holes for the steering box and of course the different front crossmember between the Gasser and the multi.
Barrman
2,231
Giddings, Texas
I forgot about those as well. My 1952 had no curved plates next to the door and running front to back so could trip over them.
hndrsonj
Senior Chief/Moderator
359
Cheyenne, WY
Alright here's a question, I just put a multi hood on the M48. It fits but upon closer look, the rear of the hood really doesn't match the M48 cowl. It looks like the cowl on the gasser is more round while the hood seems more flat. It causes the outside rear of the hood to be 1/2" or so higher on both sides. So my question is: Is there a difference or is my new hood bent?:roll:
Barrman
2,231
Giddings, Texas
Since this thread has turned into a "What is different between the Gasser era trucks and the multi fuel trucks" thing. I thought I would put another difference I found last night here.
1971 M35A2 front brake hose at the wheel cylinders is much different and much better than the 1952 Gasser version. The A2 has a hose from the axle housing to the wheel cylinder. The Gasser has a hose from the axle housing to the hub under the boot cover. Then a small "triple S" shaped brake line to the wheel cylinder. Below are pictures of the two versions. Obviously, the one with just a hose is the A2 and the one with a hose and a line is the M35.
saddamsnightmare
82
Abilene, Texas
August 21st, 2009.
Dear David:
Thanks for the insight, even though my deuce is a descendent of the Studebaker
contract taken over by Kaiser Jeep (1971 M35A2Wo/W- LD465 NA Multifuel). Between you, I and the wall, I'm still waiting for your magnum opus on the G742 (M35) series trucks, Doyle light is all right, but the doorstop version's the one I'll be looking for (kinda like Bruce McCallum's "Model "T" the car that changed the world").
Thanks again for the many kindnesses,
Cheers,
Kyle F. McGrogan:-D
1,827
There is a section in the -20 on converting the old brake hose system to the new hose system. I did the swap on my M108 and will have to do the same on the M59 (if I ever work on it)
Barrman
2,231
Giddings, Texas
I have been referring to my 1964 -10,-20,-30 and the 1952 all in one manual TM-8029 or what ever the last two numbers are. I have a modern -10, and -34P but haven't felt the need to print out the other new ones until now.
