Now These Are Brakes !
73m819 said:
i found out the hard way that there was two types of wedge, i found one type in my books, so i stoped looking, thought i was backing off the rears on the 977, hooked up to it , get out in the middel of the interesction , droped it, hooked up to the front so i could turn it around, went to bacbup, wont roll, didnt want to dink with it in the road (by this time traffic did look apon me as a postive thing), just rehooked up the rear and put it back in the same spot from where it started from.. then went in and READ the book to see what was wrong, on the NEXT page shows the OTHER type DA :idea: :oops:
Ron, that sounds like the way things go for me also! i never seem to do anything without turning it in to an adventure.
73m819
328
gainesville, ga.
when you have a 819 AND a xm977 in the middle of a intersection, all that od iron becomes a major ROAD BLOCK, plus ididnt start the turn-around till about 4:00 PM, need i say more
I'm not sure what a XM977 looks like but the M819 is a pretty good road block all by itself! i wish i could have been there to see that! I I I I I mean to help! I'm sure you were very popular.
73m819
328
gainesville, ga.
no springs, has axle stops so the axle must pivot, so i would guess some type of semi solid mount
No.2Diesel
11
Huntington, NY
Did you get a pic of the entire Mobile Crane? Who was the Manufacturer? Thanks for pointing this potential parts source DaveP. Straight air brakes are far more responsive.
joec
Vincentown,NJ
GradaLL and PH,Grove used solid mounts on some 35-65 ton cranes..With Gradall being a house mounted excavator.
No i did not get a pic of the unit. i think it was called a grade all. had a squirt boom with a ditching bucket on the end. Cummins triple nickle lower eng and I'm not sure what the upper was. it was a v configuration tho.
