ntc400 ip questions
reb87
Nebraska
My afc valve on my m919 ntc400 cummins is not working. I think the bellows has a hole. I ended up hooking up regulated air to it and could make decent power but now my ip is leaking fuel. It looks like I will have to pull the pump and have a shop work on it. I found a NIB pump from someone on here and am wondering if I could just put it on and it would work or does it have to be tuned first? Thanks, Ross
hemichallenger
deland fl
If its the same it will work but if the hp is not set the same it will not run the same. You should be able to have your pump built for $300.- $400.
WillWagner
3,163
Monrovia, Ca.
There is a tag on the top/front of the pump body. There are numbers on it. Do the CPL and code match?
reb87
Nebraska
Well his new pump is marked
NTC-400 4128
CPL-0267 JL123004
The tag on mine is just numbers
393-3537-0185432B
3017808-26014-229
My engine plate says the model is NTC400
ID 093E(family) and 0393(cpl)
hemichallenger
deland fl
It looks like your fuel filter head is mounted to the rear of the pump and the other one is not. That can be changed. If you go by the cpl number it might not be a match because it is differnt but if they are both ntc 400 big cam of the same era it should work just fine.
WillWagner
3,163
Monrovia, Ca.
Injectors might be different due to flow and the tprque rise might be different, meaning that if you use the truck to pull, you might notice a difference in the way it handles hills. I'll work, but i'd do the original pump so it can be put back to the way it was.
Southdave, that is a PT pump...pressure timed.
