numbers
emr
25
landing , new jersey
fast answer...It is called a bridge plate because it has the total weight of truck loaded and or the total weight of truck loaded with trailer or anything behind it , if trailer is in the number the red C should be placed be the top place, meaning something in tow,if no tow then it should have the blank side out. that is why the numbers are changeable ,there must be a gazzilion posts on this search for more info.. good luck... oh there is a number painted on the passenger side door in many instances that is the set vehicle weight dry,
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
The vehicle classification number represents the effects of the vehicle on a bridge while crossing it. The effect ia a combination of gross weight, speed of the crossing, and the impact loading of the vehicle on the bridge. The FM 5-36 covers this. Generally wheeled vehicles are about 85% of gross weight in tons (from DD's catalog of MV's).
Zeek
Kirkwood, Pa
I do not understand. Maybe I called it the wrong thing. This is a 8" circle with a set of changable numbers. You can place any two diget number. What do the numbers mean? If it is the weight is it in tons, like a 2 and 5 means 25 tons, etc. Is there paperwork that explains the meanings?
Thanks for the help, I am new at this.
Zeek
hndrsonj
363
Cheyenne, WY
Zeek
It is a bridge plate. Look in the FM 5-36 for an explanation. It is also in David Doyles-Standard Catalog of Military Vehicles in the back. What I posted put's it in the most basic way. EMR brought up another good point. The "C" shows a combined weight and is also located in the charts in both books.[thumbzup]
emr
25
yea its what we said it was , good luck :) see the red "C" if u put that out it means like said U have something in tow and the weight is a combined weight, if u do not have anything in tow the blank side should be out and the number means your trucks total weight, loaded, but if u are empty it should show that like a 08 or possibly a 09 for your truck i do not know if the 109 is heavier than the cargo i would think so, a standard deuce cargo should have a 08 on the front when empty, there for on the passenger side door in a six inch circle or an 8 inch circle depending on unit i think it should be in the upper right hand corner of the door 08. before the multis if u had a gasser a 06 would have been correct i believe ... now u really need Davids book :) to figure all that out... good luck
hndrsonj
363
Cheyenne, WY
Correct bridge plate numbers are:
Truck.......Unloaded.......Loaded
M35...............5.................10
M35/M105.....7.................12.......Use the "C"
M109.............7.................10
emr
25
good info, ... on a door, rick larsen sells the 6 or 8 stencils for the doors, and i also have only seen the 8 painted on doors, but we are talking bridge plates, and like u said its a percentage thing of a moving vehicle over a bridge., so the door is under a different set of rules i think ?, as for the correct uses, I see any driver just putting on the upper ( next ton idea ) number to be safe, thats what they would do in the truck co. here... :) but it sure is better to know and understand the correct way I think, good info,,,,
nattieleather
142
Cleveland, OH
The bridge plate is the weight of the truck, but the purpose for the bridge plate is really simple. If the engineers build a temporary bidge across a body of water they have a weight limit for that bidge. To heavy of a truck and the truck can not go over the bridge. So the driver of the truck or the motor pool NCO or the CO sets the weight of the vehicle on the bridge plate. Then when the drive gets to the temp bridge his plate number has to be equal to or less than the bridge's posted number. If the truck is marked a 08 and the bridge is marked 10 then he can drive over the bridge, but if the bridge was marked 06 then find a different way bub because you'll muck up the bridge. It is a way to keep things moving. The system was developed during WWII and works well.
hndrsonj
363
Cheyenne, WY
The plate is NOT the weight of the truck. The FM 5-36 emphasises that the classification is not a weight (page 101). Weight is one of the many factors used to come up with the classification. It specifically shows what is involved with getting the number. It starts around page 96.aua
http://www.survivalismforum.com/free%20manuals/1960%20US%20Army%20Vietnam%20War%20Route%20Reconnaissance%20&%20Classification%20293p.pdf
M-37Bruce
59
Midlothian, VA
I was going to suggest Rick Larsen at Mil Stencils, but his links aren't working? The last time I saw 'em they were going for 35, I gave 15 ten years ago? I guess you can check epay for George's contact info, if you get him, ask him what happened to Rick?
I guess 42.50 isn't out of the question.
Good Luck,
