Nut Size ?
redass73
Greenfield, Indiana
I am getting ready to start my hub seal job on the rear of the 816. need to know the size of the axle nuts. need to get everything lined up as to limit the down time for the truck. any tips or advice would be helpfull.
Rick
i dont know the weight of these but i do know they are kinda heavy. if you have the luxury of concrete and a engine hoist, your back will thank you. i have been working out in the dirt so i have to just bull them. even a plank and a floor jack would prob work.
redass73
Greenfield, Indiana
oh yes she will be sitting inside on concrete. I have air, jacks,fork lift and the other basic shop stuff. just dont want any surprises.. any other tips...
thanks
rick
319
Lieutenant
49
Michigan
I'd guess at 4-3/8" & 4-7/8". I don't show 4-7/16" and 4-15/16" sockets.
Let me know if you can't find them locally, I'll check my stock tomorrow.
cornrichard
Galesburg, IL
There is a thread on changing the seals somewhere here. They recommend leaving the wheels bolted to the hub and sliding them off with a dolly or on a greased sheet of tin. This is a lot easier on the back. Have fun.
Floridianson
2,439
Interlachen Fl.
4 - 15/16'' and 4 - 7/16'' inner. this is the exact measurment of the sockets. they fit just a tiny bit loose but not TO loose. now go get greasy! :)
Im going to believe that you guess is incorrect and you need to deleat you post so no one gets the wrong idea when they do a search. Thanks
crasheej
Hermitage,MO
I just went out and checked my issue socket and it measures 4 15/16 and 4 7/16 so you can call it 4 3/8 and 4 7/8 if you want I just know what mine reads.
