NV 4500 swap. What hydraulic line
RIDEBANSHEE
Nebraska
I"ve looked around and haven't found much. Im swapping a NV4500 in my 1028 using a 87 hydraulic clutch setup. My question is what did you guys use for a hydraulic line?? That is where im stuck at the moment. Thanks
paladin1176
Durham, NC
Are you talking about the one that runs to the slave cylinder? There is an internal and external slave cylinder depending on the setup you get. The last person I know that did this conversion used a piece of rigid tubing and a hand bender to get the pieces that didn't come with the donor vehicle.
cliffyp
Brownsville, Texas
Rockauto.com sells them. Look in the 3/4 or 1 tons, the 1/2's would've had an nv3500, I have no idea if that line would fit. I think the slave went from external to internal around '96.
nyoffroad
687
Rochester NY
IIRC, I took the hyd master cyl and lines off of a gas powered half ton so all of them MAY be the same. This advice is only worth what you paid for it!
