I dont see a problem with it. Dont know much about those though
I think they might be my solution. It shouldn't hit even just stock, but the clearance will be tight as I have heard. I'm talking 1-2" unflexed, throw some articulation in there and it might hit the slave. For the price and seemingly "Zero-con" install, it looks like the zero rate blocks may be a good choice.
This thread here inspired me, and although my truck is 100% stock, even down to tire size, I think if I did the zero rate blocks, it would still look stock, and probably account for any spring sag that has happened.
http://www.steelsoldiers.com/showthread.php?87203-M1028-Small-Lift-Build
All I need for the swap is the bellhousing, fluids, bolts, steel to make the crossmember and a new mount, and another CUCV starter. I need the starter because I don't want to grind my original starter if I need to and if I'd ever switch back (which would only be in a moment of insanity!)
Some backstory on the trans according to the breaker yard - Local hospital had a 6.5 K3500 bucket truck. Only used it to change lightbulbs, and just due to age the scrapped it. 19,000 miles on the truck/trans, with the PTO and hydraulic pump still attached (hydraulic winch in the future?)
To anyone reading this, once the install starts, I'm going to document it for the benefit of the forum so check back. I'll start the project once it isn't 12 degrees out everyday.
Will
