NV4500 questions
drewmech
29
Tulsa Oklahoma
Looking to swap my M1009 over to a NV4500. Having trouble identifying the NV4500 models. Found this one and the guy selling it doesn’t know what it came out of. Was hoping for some help. Added the pictures I have of it. Thanks.
87cr250r
2,073
Rodeo, Ca
It would probably be wise to start with something like this. The factory manual pedals have brackets to reinforce the firewall.
Finnegan1008
167
Connecticut
Those assembly’s sure do command a pretty penny.
What changed after 84? I would imagine a hydraulic throw out bearing would be the best setup and most pedals could be made to work with that.
Valley Rock
Big wheeler cat peeler
926
OR
I don't know but if you have a CUCV it is a 1984 model truck.
With the cookfest figure 8 pattern T-case, so you're also gonna need a T-case with the NP 6 bolt round pattern, correct input and pass drop for your cucv .
That trans is the early model they used behind the non wastegated 12 valves .
I'm not typically an auto guy, but I'd take a TH400 over that every day of the week .
Black Ops
98
Colchester, VT
1985 and up square body trucks had a hydraulic pedal assembly. I have one in my CUCV blazer with a nv4500
Mad Texan
1,151
Chester County, PA
The NP208 off a TH400 will bolt directly to a GM NV4500... 32 spline and same round pattern.
Valley Rock
926
OR
I literally forgot GM used the 4500, my brain is fried .
IF thats a GM model then, easy peasy .
I assumed it was an early dodge unit
