acesneights1
- 21
- 20
- CT
Well thanks to a friend in NY I have a nice NV4500 setup from a 93 with everything to put in my 86 K30/M1008. I hope it compliments the 4.56s gears and 35 inch tires. I will try to document as much of the swap as possible. After this then I am going to swap out the v belt system for Serp and install a Turbo(GM4). I hope to have it ready for the Mud races in Ellington Sept 17.
Here's the tranny I did 6 hrs of driving to get it and worth every bit of it. I plan on using the k30 Master with the 93k3500 Slave and line and either flare union it or use a compression fitting. Everything else looks pretty good. The flywheel I got is perfection made in china. I'm always leary of Chinese made garbage but the PO didn't have any issue with it so I'll give it a whirl.
