- 3,724
- 778
- 113
- Michigan
oldMan99
The weight is 1860, I plan on installing it up against the back wall centered under the bottom bunk bed. The battery is a gel cell so there is no need for a ventilated battery box like the other 3 systems I use lead acid in. I will reinforce the sub structure with 3" angle iron and channel to offset the constant weight in one area.
The Exide warranty is 15 years from the date of shipment which 3 weeks ago. My neighbor is in the forklift business and has a sh/t load of battery's, new/used and he reconditions them. I am blessed with good neighbors.
Are you planning on building a battery back up system for your truck or home..?
