OEM Deuce Batteries
Katahdin
24
Scarborough, ME
My hawkers I posted about earlier are coming back to life, I've been charging them indoors with a 12 volt electronic charger for the last several days (switching it back and forth). Initially the charger would abort on the worser battery at the 10-20amps setting but completed a charge using the 2amp setting. Now the same battery will take 10-20amp charge and maintain its initial charge at 80% and 90% for the better battery.
hndrsonj
Senior Chief/Moderator
374
Cheyenne, WY
Even if you charge them, they are not compatable with the deuce, you are asking for trouble. You just need to get the right batteries. Do an internet search for nicad batteries you will learn alot.
kc5mzd
Texas
I would not have a problem running them in one of my trucks. The 2.5 and 5 ton alternators are adjustable and I would not expect to have a problem. If you want to charge them out of the truck you can just use the method I told you about in the beginning of this post. Use 2 12v batteries in series with a 2 12v chargers - one on each battery. Then use a pair of jumper cables to hook the 24 volt battery to the 24 volt battery pack.
NiCad batteries may experience what they call the "memory effect" if you use them in a truck. The best way to take care of this is to leave your headlights on until the battery goes all the way dead then recharge it. You should do this once per year.
stumps
12
Maryland
Sorry, but no.
Nicad's are extremely low resistance cells. Way more so than lead acid. If you charge them with a constant voltage, you have to be accurate to better than 0.05V, and the voltage you need to charge with changes with cell temperature, how much charge the cell has, and how long you have been charging it. If you go too high in voltage, the battery will start to draw high current like it was short circuited. This will smoke your alternator, or blow fuses. If you go too low in voltage, the battery won't take a charge.
Nicad cells are considered dead when they reach 0.9 to 1.0V. During the course of a proper constant current charge, the cell voltage will rise from 1.0V fairly linearly until it reaches about 1.9V, and then it will start to drop again as you overcharge it.
Nicad "memory" is a long standing myth. The only time it ever has happened is in an extremely controlled situation back around 1962. A very early satellite had some newly designed GE Nicad cells in it to run the radios. The cells were charged by solar panels, and because the satellite was in a stable orbit, the cells charged when it was on the daylight side of the Earth, and it discharged when it was in the Earth's shadow. This charge/discharge cycle was very precise.. always exactly the same amount of charge, and always exactly the same amount of discharge. The cells developed a very refined crystalline structure on their plates, and became incapable of being discharged more than the exact amount they had been seeing as they orbited. The satellite would go dead during solar eclipse events. GE took in the information, and redesigned their Nicad cells to prevent the memory problem, and there has been no such problem since.
I know that some of you have seen something like a memory problem in Nicads. There is a problem when you over charge the cells called voltage depression. This does not change the amp-hour capacity of the cell, but it will cause the voltage on a fully charged cell to drop about 0.2V. The solution to voltage depression is to stop overcharging your batteries! That means no more trickle chargers!
Do not fully discharge a large Nicad battery in hopes of curing "memory". This is a very bad thing to do because the weakest cell in the battery will discharge completely long before the other stronger cells do. That will cause the weakest cell to be reverse charged, which will cause it to die a quick death. A 24V Nicad battery has 20 cells. It should never be discharged below 20V.
-Chuck
kc5mzd
Texas
I DO AGREE ON NOT DISCHARGING DOWN TO ZERO.
Now that you have reminded me I do remember a lot of problems with cells reversing their polarity.
I used to work for a power tool manufacturer in their factory repair center (a long time ago). I used to take old battery packs that were headed to the recycling bin apart and "fix" them. I would not want to even think about trying it in that size battery.
It seems like if the alternator was adjusted properly and the battery was not taken below the 85% charged threshold it would be fine.
Most modern electronic computer controlled car battery chargers are constant voltage and constant current. You can set them at 10a and they will charge at 10a until the voltage hits a certain point then they start to reduce the current to maintain a constant voltage.
We also did see batteries that would develop what the tec sheets called "the memory effect". Running them down to the point the tool lost most of its power then recharging did seem to make a big difference. It was to long ago to be able to describe what the mfr said was the cause. I think it had something to do with one of the chemicals crystallizing or something like that?
Again I would not recommend running the battery down to zero.
That advice was not thought through.
I still think it would be a good idea to once a year turn on the headlights until there is a noticeable drop in brightness then recharge the battery.
I still think it would be ok to use jumper cables and 2 modern car battery chargers to charge a partially discharged NiCad. At least it is something I would try if I had the 24v battery *ok so that doesn’t always mean its necessarily a good idea*
