Off-road capabilities?
Woodsman
New Albany, IN
I've tried searching for some of the information and not having much luck finding this for a stock M1009:
Approach angle = ? degrees
Departure angle = ? degrees
Breakover angle = ? degrees
Side Slope Capability = ? %
Upslope Capability = ? %
Vertical Scaling Capability = "?
I was curious to how this vehicle stacked up against a H3 I used to have.
Somewhere I thought I had seen a data plate or a drawing with this information shown by an outline drawing, but I may have gotten it confused with the data plate showing the GVWR plate showing the CG locations, etc.
Thanks in advance for any input.
flighht2k5
Banned
322
It's a typical civi blazer. Just google blazer and you'll find it.
OL AG '89
9
Kingwood, Texas
It's all relative to what you do to the stock vehicle. If you put 33's on it you get a little better clearance, put 37's and a 6" lift then even better, but you sacrifice driveability with the more height you try to get, also need to consider changes in driveshaft angle and other issues. More topspeed, because of gearing, but if your off-roading, more speed is not a big bonus....
H3 is not comparable, it has soft leather seats, a.c, stereophonic sound, heater, electric toothbrush holders and on and on...
CUCV is stripped metal interior with padded dash.....and idiot lights
6.2L diesel is a good engine, yep I said good..... doesn't have a LOT of power but used correctly, doesn't need it...
Left stock, it's a decent daily driver, build a little lift into it and it's still a decent daily driver...
DokWatson
Wasilla, Alaska
M1028 is very capable stock, detroit locker and limited slip differential in 1 ton axles. M1009, not so much with open differentials and 1/2 ton axles...but still better than an H3. No IFS systems to break.
Those numbers don't mean jack, never heard of a vehicle being judged by angles.
Marlboro
Mullica Hill/NJ
Ahh... Is a 09 better, more capable then a H3,... Well depends on whos driving them? I've seen Great drivers take **** trucks down some nasty trails. A vehicle is only as good as its driver :driver:
jamesfrom180
71
Gainesville/Florida
Only approximation since I figured you could benefit from some numbers before the lecture. Sometime the guys here get a bit grumpy [thumbzup] let them have their say there is wisdom in it.
Approach guessing about 48-55
Departure 45-60
Break over 25 with max height of 1 foot
side slope no idea 1:2.5
upslope and scaling I think those are primarily a function of driving but my guess would be not so good.
Now if your trying to bate people into a discussion of the merits of a H3 compared to a M1009 good luck.
Bighurt
46
Minot, ND
I have to agree, however like in carpentry, not everyone is a miracle worker. You can't take a shipping pallet and make a carved wood bowl...
Everything has it's limitations. But the skilled driver knows when to find another route...
Bighurt
46
Minot, ND
Capabilities aside you will find a M1009 in my garage before you find an H3.
Of course you will also find a huge list of stuff, before an H3. In fact if you gave me an H3 I'd just sell it and pocket the cash for another MV purchase. LOL
Westech
CPL
6,104
208
cow farts, Wisconsin
I have never broken one in a M1009... even with 5" lift and 33 mud tires. Its all on how you drive and put the power to the ground. If you Jack the throttle and get all nutty its going to brake.. if you use your head they will last and work great.
Woodsman
New Albany, IN
Departure 45-60
Thank you!. Just wanted to look at the basic info.
Nope, that was not my intention. I'm shopping for a M1009 and wanted to understand how the spec's stacked up and what might be required to get a stock M1009 into a daily driver with these fewest mod's.
Barrman
1,779
Giddings, Texas
That really depends on what you want for comfort in your daily drive. No a/c, no tunes, no rear doors, manual windows and locks along with no cup holder. If you add a civilian K5 center console, or make your own the cup holder and storage issues are gone. Then it comes down to what fits you.
I drove my M715, M35 Gasser or M35 Whistler pretty much daily for many years and think the M1009 is the lap of luxury. It is compared to those vehicles. Your opinion and frame of reference might vary.
