off topic Kubota lowboy GL11000
justacitizen
40
oklahoma
there is a local to me Kubota GL11000 either a 10K or 11K series II generator for sale pretty cheap. the owner says he had the unit in storage no mice. and when he started it to give it a monthly run the battery light flashed and the big gen quit producing power. has anyone here any experience with these? would this be an easy cheap fix??? any opinions are welcome.
jamawieb
536
Ripley/TN
Probably not cheap. You can't get the manuals for them unless you go to the dealer. Most Kubota dealerships don't work on them and have not idea what they are doing. I've had a couple of people by 803a's after buying the Kubota that crapped out on them, that no one could fix.
justacitizen
40
oklahoma
yea that seems to be found mostly everywhere i look. also i think it is a fast turner 3600 rpm. boy that would be a let down to buy a 7000 dollar gen and have to throw it away because it quit after 400 hours. i will stick to the MEP
Light in the Dark
5,617
MA
Yeah they are full speed. I think there is a reason you dont see many on the resale market.
Light in the Dark
5,617
MA
Low sales volume, coupled with specialty commercial repair network.... diesel gensets of this size are in the 'middle'... too small for serious commercial work, and too big for simple jobsite tasks. So the commerical units that are in service are kept up until not economically feasible (or are destroyed and not rebuilt as companies can write off items like these).
diesel583
N E Okla.
We had one when I worked for Ok Forestry, took it to Clifford Power in Tulsa. Had to haul it from Goldsby to Tulsa cause nobody in OKC would touch it.
justacitizen
40
oklahoma
seller indicates when he started it the battery showed bad and it simultaneously stopped producing power. has a good battery in it and it starts with a bump but no AC.
justacitizen
40
oklahoma
yes that is possible. i found an online operator manual and it has some wire schematics and a few troubleshooting. there is a slow blow fuse in the 12 volt circuit that could cause no AC. it also has brushes and slip rings.
justacitizen
40
oklahoma
i found a workshop manual. there is a symptom listed in the troubleshooting that fits. it could be a bad stator or just a loose connection. the problem is a new stator costs 2700 dollars!
