Official 2014 SS Ga. Rally buy/sell/trade thread
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
I have-
Gas powered 3kw 2bv DC genset, $225.
Small 2.5 gallon Russian Jerry cans- these make great oil cans for carrying enough oil for an emergency change. I have 2 grades- good inside with no or very little rust $15. With rust inside or flaking lining, very restorable $7. All need repaint outside.
HMMWV Pioneer racks, new in box, $30 rack only
NOC GM CUCV door weatherstripping, $25/side
Used good NATO Jerry Cans $35 will have nozzles as well.
Chief,
If you have any left unspoken for I would like 2 of the boxes of the CUCV weather strips. Enough for one vehicle is good for me.
1,192
I will have 809 series 5 ton front winch shear pins for sale.
Catch me at the rally.
juanprado
3,167
Metairie/La (N'awlins)
Military Wrecker spotlight
24v Military used spotlight off a M936 wrecker. Universal applications.
spins and pivots freely. on/off switch on housing. Bulb included. Bulb and switch tested- good. With wiring pigtail with connectors. With mounting bolt & nut and bracket.
$60
Chief_919
105
Western NC
If anyone wants any German military field phones I will bring them. They are all tested and working, they have dates from the 50's through the 90's although they are very similar to the WWII model.
Uses field phone wire just like the US ones, or can use single strand wire with the other side grounded if soil conductivity is good. Range up to 22 miles if you want to run that much wire.
$45 each
Boy Scout wall tents- heavy duty canvas, they measure aprox 9'x7.5' and are 7' tall in the middle. $175 each, tent only no poles but I have the plans for a frame with dimensions. Perfect for events like this.
Wood ammo crates- 37"x12"x8" (aprox, they vary a bit), most are 70's or 80's dates. Rope handles. $10 each, need a good count of who wants them to be sure I bring enough
auctionaddict
blue ridge, ga
HMMWV underbody protection kit $ 125
4- batteries 6TAGM from MRAP's there 2012 dated and I will bring a load tester. $125 each
Also
Joystick for mrap turret $100
Motor/drive for mrap turret $200
Controller for turret $ 100
mrap 2400 watt inverters 24v-110 $ 100 each (unknown condition)
CTIS boxes $125
LED master switches used $75.00
24v blue dome lights hmmwv $30.00 each
LMTV high speed gear sets $1000 set of 2
MIGHT have this if the sale on my LMTV falls thru tuesday...
2- red dot ac kits for 915 series trucks $ 400 each
Yanmar retrofit L100 engine new $1000
wreckerman893
Possum Connoisseur
15,646
2,136
Here are some things I found while scrounging around the compound.
Pic 1 and 4 are from a 5 ton. Not sure if it's a 800 series or earlier. 20 bucks
Pic 2 and 3 are a deuce J pipe and a set of mud flaps from a 900 series dropside bed. J pipe sold.
Pic 5 is a set of rails from some type of HUMVEE mod kit. I have those two and two still in the boxes. 35 bucks each.
Pic 6 is a 5 ton transfer case that I mistakenly took out of the M923. It should be good since I discovered the real problem was a bad axle making the noise. 250 bucks which is what I paid for the one I installed.
Pic 7 is aluminum flex pipe that was used to remote generator exhaust. 10 bucks a throw. I have several.
wreckerman893
Possum Connoisseur
15,646
2,136
More stuff.
Pics 1-4 is a small alternator. 14 volt, no idea what it's off of. I have 10 and will make someone a deal on all of them or 50 bucks each.
5 is tie rod ends, no idea what they are from, got a butt load and will sell them all for a song.
6 is misc rubber hoses. 5 bucks a pop.
7 is some sort of exhaust pipe NOS I have 2 50 bucks a whack.
8 is a suction water hose from a mobile photo lab I scrapped out. 20 bucks OBO or trade for something equally useless that I don't have.
