Official 2020 Georgia Military Vehicle Rally buy-sell-trade thread
1,163
Ok folks, the 20GMVR is almost here and this is the buy sell trade thread.
Here's how this works: you post up what you're planning on bringing to sell and what you're looking for. And commerce will commence.
Here's my lists:
I am looking for:
A pair of NOS highback M44A3 or HMMWV seats. Don't need bases.
A good whistler turbo for 2.5 ton multifuel
I am selling:
Nothing I can think of right now.
98G
Former SSG
4,866
Here's my lists:
I am looking for:
I am selling:
I have one high back hmmwv seat, attached to a battery box cover (passenger side obviously). It's in KS. I don't plan to attend the GA rally, but I suspect Dave will so perhaps we could hitch a ride with him.
1,163
I have two M44A3 seats in my truck and the covers are trashed. I'm debating what to do: get them recovered locally with Cordura, at a high cost (minimum $400) so they match, or hope to get lucky and buy an NOS pair.
  • Like
Reactions: 98G
Elijah95
Certified Rookie
1,246
1,221
Georgia
For sale: Only bringing items if pre sold!
M989a1 HEMAT trailer, 90% tread on all 4 tires, $2000 obo
M1061e1 5 ton dual axle fuel trailer w/600 gallon aluminum fuel tank, 50gpm Scott fuel pump powered by slave cable, comes with fuel gallon meter and dispenser nozzle.
$3000 obo
M105A2 mint condition restored, extended frame with front deck plate, LEDs, MINT S250 shelter with breaker panel installed, 30amp RV plug with 25’ whip, M35a3 wheels on 14.5s and good spare tire/wheel included. Lots of upgrades across the entire trailer. Reduced to $3500
Trucklite LED tail lights and front turn signal set (4) lights total in mint condition
$300 obo
(2) M931 stainless steel fuel tanks 50 gallons each, very clean and ready to go.
$300 each or $500 for both obo
M939A0 spare tire carrier assembly and crane for 11.00r20 tire size
$125 obo
(2) Hunter camfire 60,000 btu diesel/oil fired clean air heaters, exhaust exits upwards and warm air blows towards you.
$250 for both (one is a parts unit)
M35A2 starter, used takeout $150
MRAP steel round fuel tank DOT rated $200 has sending unit in tact
MRAP miniature aluminum fuel tank $125 includes sending unit
Large diesel high flow muffler $50
MRAP intake assembly with air filter and spinning pre cleaner $100
M37 blackout light assembly stripped and primed $20
(13) total 9.00x20 NDTs with tubes and flaps
(2) are BRAND NEW never mounted on a truck
(3) are less than 40% tread
(8) are 65-70% tread
(A couple are mounted on deuce wheels)
$625 obo
(11) 5 ton split ring wheels
$5 each or $40 for ALL
M939A0/M939A1 stubby jackshaft between tranny and t case, good U joints
$200 obo
M939A2 series front driveshaft w/good u joints $100 obo
Interests:
MTVR parts
90% + tread 16.00 XZLs 2014 or newer no flat spots
M35a2 air shift transfer case
M35a2 air shift case install
M35A2 New 2 hole injectors
MEP803A generator
Freightliner SEE
Cranes/Wreckers
Large, newer civilian pull-behind campers
1,827
Greetings friends. I am seeking a brush guard/ grill guard for a CUCV. Sadly, I am unable to pay for gold plated ones. If you have something you can bring, let me know. Don't pm me, I still can't find my pms on the new format.
MWMULES
352
DESOTO, KANSAS
Top right of page, just hit the envelope by your user name
1,163
I wish I'd know this a couple weeks ago. I dropped off one of our Land Rover D1 parts trucks at the scrapyard in Braselton and there was a pretty stripped 1009 there with no axles, powerpack, interior, but it had a perfect grille guard on.
1,827
My luck runeth over.
SCM35A2
3,360
Florence, SC
Stole these pics from a previous thread, but I'm looking for the storage box, pioneer tool kit rack-(rack only, I have the tools) & the rear shackles off a late model 5ton truck. The color of them doesn't matter-(tan or green) just as long as they are not damaged/banged up. Thanks
SCM35A2
3,360
Florence, SC
Also looking for the shifter assembly/top section if possible for my 91 M923A2 5ton truck. In the pics you'll see that mine has cracked & there is now a hole & Id like to replace it if this part is something that can de swapped out. Here are some pics of what I'm looking for...
wheelspinner
1,540
North Carolina - FINALLY !
If I can get them all finished up- I will have 3 complete HMMWV Swing spare tire carriers. Each will be $1,000 but will probably only make the trip if prepaid (and not sold otherwise before)
I have a complete tow bar with all pins and 3/4" feet for $350(SOLD)
I'm sure I will did out more stuff as I'm moving things around
**I am parting out 2-3 FMTV so if you need something, check with me. Thx**
mdmorganwife
15
Forsyth Ga
1968 M129A2C military van trailer. We completely gutted the inside, repainted and installed spray foam insulation. Installed a side door. Comes with 2 sets of aluminum steps. Installed fold down steps/handles on the back door for access to the roof. There is a RV air conditioner mounted on the roof, but it's damaged, FYI it won't fit through a 12' door. Rated as a 12 ton trailer.
Overall length is 28' 8.25"
height 11' 7 3/8"
Width is 8'
Weight approx 15,400 lbs
Payload 24,000 lbs.
Would make a great camper.
$3500
