Blake
- 63
- 28
- Opp, Alabama
Does anyone have any NOS - 10 leaf front leaf springs for an m38?
Curious if you had an instrument cluster? Base of mine has cracked and several attachment points have broken.I sold my CUCV and have the following used takeoff parts (unless otherwise noted) avail. I go to the rally for the good time and wont bring unless there are prior commitments. PM for questions or addition info.
m1008 fuel tank complete - $75
m1008 brake booster/ master cylinder - $75
CUCV radiator / came out of a parts truck - $150
CUCV injection pump core $100
CUCV steering box - $50
CUCV power steering pump with bracket and hoses - $250
m1009 rear drive shaft - $100
m1009 front drive shaft - $100
m1008 rear driveshaft - $250
m1008 front driveshaft - $100 - Matt444
New AC delco 6.2 water pump - $75
New purolator, fram, and casite engine oil filters - $3 each
New m1008 front brake hoses (to calipers) -$10 pair
CUCV air filter housing - $25
Complete 6.2L engine/unknown condition with no accessories - can take large or small parts off as needed
CUCV NP208 Transfer case - $150
CUCV TH400/torque converter / unknown condition (taken out of a parts truck) - $250
CUCV torque converter - $50
CUCV stock fuel filter housing - $50
M1008 rim/tire - $50
M1009 rim/ tire - $125
CUCV 24v gear reduction starter - $75
CUCV fan/clutch - $25
CUCV intake manifold $25
CUCV engine wiring harness - $250
CUCV dash wiring harness - $300
CUCV steering column - $75
Miscellaneous CUCV engine parts - PM direct for parts request
Miscellaneous:
PRC25 and am2060 amplifier/power supply - $500
Large "wrecker" snatch block with loop/swivel on end - 3/4" cable - $200
M116a2 with MEP-003a 10KW diesel generator with fresh/new crate engine (must pickup in southeast virginia/ wont deliver to rally) - $2900
NOS Autolite "2245" military spark plugs for jeeps/trucks. Packaged under AR7S, 1966 date, made in USA- $30 each
Temper frame tent - 2 sections with ends. Total 16' long by 20' wide. Vinyl sides (tan) with vinyl ends (green), rain fly, raised stanchions, and floor. Extra vinyl tan sides. Stored inside. Frames in carrying bags. $800 for all
M35a2 outer windshield frame (no inners) - $75
M35a2 soft top bow/side pieces - $100
M16 military metal rifle rack - $75
I don't have that much right now but I could probably get you a case or 2Who had the cases of brake cleaner in past years?
Lance
Thanks, Matt. If you have a couple of cases I'd really appreciate them. Non-chlorinated preferred but either is OK. Please let ma know how much and how you want to be paid. I'm not sure if I'll be there Thursday evening or Friday AM yet.I don't have that much right now but I could probably get you a case or 2
Sent from my SM-S906U using Tapatalk
Me too!!I don't have that much right now but I could probably get you a case or 2
Got a handful of mtvr bows and corners for a mtvr which are identicle for a 5 ton but unfortunatly not going to make it out to denton. Limited on staves.Folks, I am in need of a deuce or 5 ton complete bow. Just one for now. Bow, 2 corners and 2 staves.
I have a guage cluster from my m1028 I would let go.Curious if you had an instrument cluster? Base of mine has cracked and several attachment points have broken.
I have a set .I'm looking for front and rear drive shafts for a Dodge M37 if anyone has them.
I will be there with a few parts from my m1028 project and some M12 gun racks to sell.
One thing I am looking for is a tall boarding ladder for my truck. I'll have to get some measurements and see what I need. Probably find one that's extra tall and cut it down.
Looking to buy two Humvee antenna bases and whip antennas to mount on my Humvee. I’ll be there Saturday morning.
Find Todd Hergott I think he may be bringing some. If not a guy on Facebook has some NOS AS3900 ones for $250.00Looking to buy two Humvee antenna bases and whip antennas to mount on my Humvee. I’ll be there Saturday morning.
Todd is here and has plenty it looks like. Look for his trailer painted as a .50 cal ammo can.Looking to buy two Humvee antenna bases and whip antennas to mount on my Humvee. I’ll be there Saturday morning.
Hey Matt, if nobody has claimed the old style strobe light bar that you have then I'll take. I'm still not 100% sure If Ill be able to make it to the rally, but I can make a trip up to you to pick it up. Message me & let me know.M105 trailer comes with steps, newer vinyl cover, ac, toolbox, and bed $1200 make offer
Can't have till Sunday
Old style strobe light bar 12V works but needs new bulbs $100
M105 trailer vinyl trailer cover $100
M35 cargo cover $200
Outdoor sink $50![]()
I will check it over well and let you know for sure. Today with the rain we are just going up quick to see what's for sale. We may come on Sunday to sell stuff if people will still be there.are the attachment points and ribbon on the back in good shape?
