oil change mess up
rev.chris
Fillmore,WI
OK, i changed the oil and filters in my deuce, start it up and i have oil dumping out of the both filter housings, what did i screw up?
m109guy
27
ON
Could be multiple problems.
Are the gaskets at the bottom of the cups still in place and in good shape? As well as the small gaskets at the top, under the bolt head?
Did you tighten the housings down enough or make sure that they are sitting in the flange properly? If they are not tight enough, or are sitting even just slightly off, oil will find a way to get out
Did you make sure to put the drain plug under the filter assembly back in? Some people forget to put the plug back in, as it sits in a bad place.
Try checking all that and see if you find something :)
wiggall
151
Lenore, Id.
Did you use NAPA filters with their gaskets? If so the NAPA filters come with the WRONG gaskets for a Deuce:!: I might be able to get you the NAPA part # for the right gaskets later:!:
jatonka
87
Ephratah, New York
I have the Napa 5119 correct gaskets if you don't find them locally. There are oil filter adaptors to trouble free spin-on filters available too. Pm me for info. JT out
cranetruck
75
Meadows of Dan, Virginia
Carquest 85133 comes with the correct gasket. When torquing the filter housing bolt, don't turn the housing, keep a steady, firm pressure on it.
Do not overtorque, the fine thread insert in the cast bracket may break loose.
Right click on image and open link in new window for full res or go to PS Magazine section (old site) for all info.
FreightTrain
Banned
2,730
13
Gadsden,Al
heck,my napa filters came with correct gaskets.think they were napa gold 1133s,Came with the incorrect thin,the correct wide,and a washer gasket that don't fit the top......
dabtl
Denton, Texas
Some how JT has become the major source for the correct gaskets around here it seems.
For a guy selling the spin on adapters, that is very generous.
jimmcld
Denton, Texas
You can also get the cans cocked to one side if your not careful. From the amount of oil that you described, I would check that first. As was stated earlier, push the can up in place before tightening the bolt. It's a real pain and I think you will probably be a good candidate for some spin on's by the time your finished.
chaplain
san antonio tx
Hee, Hee, I had the same problem 30 years ago. I had oil everywhere. Oh the memories. Definitly a gasket problem and I still remember that in my case I put the gasket in wrong. Glad you got it fixed. Yep the boss was mad at me took hours to clean up .
chappy
WillWagner
2,553
Monrovia, Ca.
Isn't it amazing how a quart of oil on the ground looks like 10 gallons :roll:
BugEyeBear
Eastern Georgia
:ditto:YUP!
I used to have an old VW Van that marked it's territory everywhere it was parked.
Looked like it dripped a quart in every parking spot, BUT I never had to add any oil between changes!!
I SWORE it somehow MADE OIL!!! :confused:
-Bear-
