serp
- 0
- 6
- new providence nj
with engine at idle, if you remove oil fill cap should you see oil flying around or should everthing just appear wet with oil ?
Did you shorten the housing and the bolt to use the shorter filters?dmetalmiki said:I used 2 B all of an edgy waiting 4 oil prssure climb ! NO MORE! cut down the oil filters to 2" yep! 2"..small element in those, and WHAM! insta oil presh !. (oh..and 120lb SOLID line gauges on both my M35/M54/ )..NOW im both sure AND happy!.........converting my M45 same ..next project.
All the Multfuel ones except the 361 manual - at least all of them that I've ever seen....this is not referring specifically to after an oil change, but rather, any time the truck is started.11ACR-LT said:Which TM advises to pre crank,
I couldn't tell you exactly but my '69 Kaiser and my '73 AM General were/are both to the right of the steering wheel.rmgill said:Re that PS magazine article. When did the starter button move from left of the steering wheel to the right lower of the steering wheel?
