OIL Dipstick
SSG ALBANESE
Monterey, California
Good morning everyone. Need someone to do me a favor.
Can you:
1) measure they entire length of your oil dipstick.
2) From tip to low line.
3) and tip to full line.
I had a few rebuilds going on at the same time, I am pretty sure I have the correct one but want to be positive.
Thank you.
OLDCHEV4X4
Glenmoore PA
I also had a dip stick problem on my M1008. After I did a oil and filter change, filled with 7 qts, it still showed a quart low on the stick. I checked the tube to see if it was all the way seated and bolted, and it was. Guess I will check against the measurements terracoma posted.
