Oil drenched air filter.
CucvFML
Bay City, MI
85 m1009 25k miles daily driver. Lately its been throwing clouds of smoke during any acceleration, and my air filter is covered with oil. Any ideas on what the problem might be?
Westech
CPL
6,104
209
cow farts, Wisconsin
Autozone... oriley.... napa....a civy part. you will have to go in to the Stant (sp?) book. It will NOT list it under trucks. I think i found it under olds diesels.... but get the buyers guide and look its in there! like 15 bucks tops.
wayne pick
Valley Cottage NY
The CDR valve is most likely clogged or damaged preventing the spring and diaphragm from working properly. It will dump excessive blow by gases and oil into the intake. It can be cleaned or replaced. Replacing it is a better option.
cpf240
Free in Northern Idaho
Ok, thanks. I was under the impression that it was NOT the same as the civy version, as I've read posts here where the civy one is just a cap, not a breather, due to emission controls, etc.
wayne pick
Valley Cottage NY
There is really no need to replace the cap. It can be cleaned with degreaser spray and water or brakecleen. After cleaning, shake the cap, if it rattles it's good to go, if not then clean it again. Let it dry naturally after cleaning.
