I just spun the fan by grabbing the blade. I had to modify a tool to get it off.It's a m1123. Other question. So to remove serpentine belt. You put a 3/8 breaker bar on #7. The fan blade is perfectly aligned with that 3/8 hole and its too close. I even have a flat bar 3/8 for belts and it still can clear. Can engine be rotated from harmonic balancer or is a bolt going to shear off
Remove the right inner splash panel to get to the tensioner to loosen the belt. The back side of the balancer has 3 or 4 large bosses that a wrench fits on to easaly rotate the engine.It's a m1123. Other question. So to remove serpentine belt. You put a 3/8 breaker bar on #7. The fan blade is perfectly aligned with that 3/8 hole and its too close. I even have a flat bar 3/8 for belts and it still can clear. Can engine be rotated from harmonic balancer or is a bolt going to shear off
