Oil Filter Gaskets M35A2
russojap
Knoxville TN
I didn't spin the cans while I torqued them, I made sure to hold them so they wouldn't move. They weren't leaking at first, but started leaking after I accidentally revved the engine up while starting it. Later I accidentally revved the engine up again when starting it and now they are pouring.
M35A2-AZ
417
Tonopah, AZ
Did you clean the seating area good before you put the gasket in the grove and seated it all the way?
texas30cal
87
Brenham Tx.
Idk, I haven’t used 5119’s yet but I will be before Saturday, I guess try again. Check the groove, mating surfaces, defect on the edge of the canister maybe? I’ve seen a bent canister hold down bolt that caused sealing issues. How much oil pressure is the truck making? Is the oil pressure regulator stuck causing 100+ psi like I’ve read about here? If so what would normally be a small leak could become a big one?
1,187
Did you torque the center bolt to 60 ft/lbs?
wix # 15070, napa 5070, 5221 or 5406
The picture of the napa 5070 looks like it's rubber but it does it say what material it is.
https://www.napaonline.com/en/p/FIL5070
1,187
And it looks correct for the secondary fuel filter gasket!
I pulled the info I posted from a search.
Sorry to mislead.
