- 12,195
- 329
- 0
- gainesville, ga.
The seal is not a pressure seal, no pressure no leak for a good seal and seal surface, the rear seal is a standard design, take ANY floating axle hub apart, you will see the back seal. take a look at the (hate to say this) cucv's rear floating axle, you will NOTE no outer seal because it has a wet hub, the only thing different between a cucv floating axle and a deuce/5t floating axle is the SIZE, ANY seal will leak if the seal or the surface is crap, GREASE just helps hide a bad seal/surface and again a seal not designed for pressure WILL leak, A rear end is supposed to be pressure naturally. (NO PRESSURE)The normal inner most seal won't retain oil by design. That's why they tend to leak so easily.
