engineer233
I have a small oil leak to say the least. I have a M923 with a NHC-250. This is my first 5 ton and am going through a learning curve with it. On the way home when I picked it up it started leaking 1 gal every 50 or so miles. Got the truck home and pressure washed the engine , later started it and it run for at least an hour and nothing. Took a 3 mile drive and raised the hood and here we go again. The oil is slinging off the fan pulley. The only logical reason for this I can tell is it may be coming from the accessory drive pulley ,but can't really tell as the fan has blown it all over again. What else can I check or what common problems could this be ? My truck runs 30psi on the oil at idle and 90-100 at highway speed. This is of course at operating temps. What should this be or is this normal ?
