donttreadonmebmg
- 1
- 0
- Ashtabula Ohio
OK here it goes. I noticed yesterday the M52A2 I just bought
is leaking oil from the front. seems to be around the tach cable (ns). plus it's leaking from probably the rear main. I also noticed the oil level is up above the oil full mark and it seems to be blowing a lot of oil out the crank case vent tube.
the $500.00 question is what's wrong lol.
I figure it's leaking diesel from an injector and thinning the oil and the leaky injector has washed a cylinder causing blow-by. blow-by is causing pressure to build and cause the leaks from the front and back. maybe not because the vent is allowing air to escape again I'm (ns).
OK guys let me have it give me your input.
I can take the bad news. rebuild???
When I bought it, it had some oil around the rear of the oil pan but now it has more than I like. but that's OK I can live with a little bit leaking from the rear but the front leak is far worse and needs fixed. any Idea as to how to fix this? The oil blow by is bad coming from the crank case vent tube it's all black around area below the tube and wet with oil. seems to run alright still but I don't want to run it until I change the oil or rebuild the engine.
One more question having never worked on these engines before can I re-ring it from the bottom without taking the motor out and removing the head gasket? I've done that before on big diesel farm tractors.
Well let me know and thanks guys I love this beast!![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
