oil on the side of the block
DUECE-COUPE
Scurry. Tx
Been seeing oil on the drivers side of the block. can some one tell me if this is the tell tale sign of a blown head gasket. truck runs fine, but i keep seeing it after i clean it off with carb cleaner..
jatonka
57
Ephratah, New York
Injection pump has an external oil line to it, very leak prone. Aircompressor has an eaxternal line to it and large gasket area for oil return to bloxk, somewhat leak prone. Valve rocker cover gaskets can leak some times. Generally if you blew a head gasket, you will know it. JT Happy New Years too.
