- 7,408
- 2,501
- 113
- Interlachen Fl.
Ok there are two plugs one for the bellhousing and one for the oil pan. The shorter is for the bell housing / fording so as not to hit the starter ring with the threads. Now mine came with the shorter one installed in the oil pan and not one for the bell housing. Mine someone used a bad ratchet or something and damaged the center but I was still able to get it out. Ordered an oil pan drain plug to replace the bad one and they sent me the longer one. Went to change the oil and the longer plug would not screw in all the way. There must be damage to the threads deep in the pan. That is ok because I call MWM and John sent me the shorter one for the bellhousing that has been working just fine for the oil pan. I am not going to pull the pan or get a thread chaser to repair the upper threads in my pan as said the shorter one works just fine. So just remember use a good square 1/2' something that will go in all the way and not damage the plug. OK deal free oil pan drain plug if you are the first person to tell me what this hood ornament came off of. And free means no shipping cost Free and it was never fully installed so crush washer is still uncrushed.
