Oil Pan holes 6.5 turbo
daveiaff
Pittsburgh, PA
I haven't picked it up yet, but the pan will be the first thing off. I needed crossover for manifold, dip stick, front pulleys, valve cover, and a few misc. parts, after finding them on different sites and adding shipping and tax, it was easier for me to buy the whole motor.
rtk
422
Lockport N.Y.
I would say it lost a connecting rod . probably a lot of damage to the block and the internals .
gringeltaube
Staff Member
2,313
Montevideo/Uruguay
That engine looks fairly new; probably did not survive its first test run...
$500 (+ cost for pick-up) is fair enough just for all the external parts. Heads, manifolds, turbo, IP, injectors....that alone is worth much more, if you had to buy everything, separately.
NDT
6,004
Camp Wood/LC, TX
Is that a GM or GEP engine? GM will have GM embossed on the valve cover, GEP will have a label on the valve cover and Navistar diamonds in the engine valley.
MarkM
CODE BROWN...It's all going to sh~t !
1,837
WOBURN. MA.
Yes those dents/holes look like they came from the outside in so it is possible the motor itself is ok. Once the pan is pulled the tale will be told.
Mark
Milcommoguy
2,123
Rosamond, CA
First glance look to from the outside. After a closer look does look like something tried to escape. Still lots of parts, CAMO
Barrman
1,653
Giddings, Texas
I have a pan that looks almost exactly like that. Rod bearing furthest from the oil pump complain first when there is no oil. Rods, crank and probably some trimming to get the jagged edges of the #1 and #2 cylinder sleeve smooth again should have you running again. Plus, all the usual rebuild stuff.
daveiaff
Pittsburgh, PA
Just went through a 6.5 NA complete rebuild, block, crank, and rods were all good on that one. .20 bore to clean up the cylinders, should be running soon.
