Oil Pan replacement 6.5 L NEED HELP
DefendersMN
9
ROCHESTER MN
I have a dented oil pan on my M1123 6.5 L NA Diesel. I am trying to replace, but the starter is in the way of some of the bolts that need to come out. Do I have to remove the starter? Any tips, tricks? All the Technical manuals seem to feel it is a snap ( TM 9-2320-280-20-2 section 3-6.) Thanks M.
Action
1,555
East Tennessee
You should read all of the directions in that section 3-6.
Equipment Condition
* Starter removed (para. 4-8 )
* Oil dipstick tube removed (para. 3-2)
19,462
Starter has to come out first...
Otherwise you just can't reach the pan bolts.
I know you will - but be sure to disconnect the battery cables first!
DefendersMN
9
ROCHESTER MN
I got it done. Removed the cover over the starter gear, starter comes down with three bolts. You need a crowfoot wrench to loosen the front bolt on the starter. Oil pan was so dented I had to bend it a bit so that I could get the starter down! Oil pan was RTV sealed something fierce, chisels etc. new one went in no prob. I used permatex black for RTV.
NDT
6,233
Camp Wood/LC, TX
Nice work cleaning up the mating surfaces. I know it sucks doing that with oil dripping in your eyes. Is that a GEP engine? Never seen the red paint marks before.
19,462
Really interesting... As I was looking through the pictures I had the same comment as @NDT - about how clean the bottom of the block was. You definitely Done Good there! Guessing that you bent the oil pickup tube back down to the bottom of the pan too?
cwc
147
Sweeden, KY
I have a Melton rebuild here with the red paint on the lower end bolts, came out of Albany in a M1045A2.
Sent from my E6910 using Tapatalk
