Oil Pressure Gage Missing for GSA Pickup
rumplecat
246
North West Arkansas
My oil pressure gage is missing on a M813A1 I have to pickup from GSA, I can only do minimal maint. before moving the truck, I don't know if the gage is just missing or if the wiring is still there. What are my alternatives (quick and easy) I am not running it without a oil pressure gage of some sort!
Westech
CPL
6,104
212
cow farts, Wisconsin
that gauge is a mechanical gauge in the 813's (at least it is on mine and the others I have seen) . You will want one back in there or oil will be spraying all over the place.
doghead
4 Star General /Moderator
1,193
NY
Why not pull a gauge form one of your other 5 tons?
Actually, why not just tow bar it home?(no preview?)
rumplecat
246
North West Arkansas
That was my first idea but I don't know what is under the dash, I should have checked when I was there but there were six possible auction wins and limited time to look, and it's eight hour drive from home! Is there a cheap option, one I can screw into the block or something I can improvise in case just adding the gage doesn't work?
R Racing
St. Leonard, MD
I could be wrong, But im pretty sure it should be a 1/8 inch pipe thread.Every one I have seen removed has the hose comming up into the cab since they removed it from behind the gauges. I would buy another gauge and bring it with you. If you want to plug the line you will need a 1/8 " pipe plug.I'll take a peak at mine and verify for sure.
doghead
1,193
NY
I can't remember where the oil pressure line comes off the cummins motor. You could probably just screw in a gauge where ever the gauge gets it's oil pressure from, but a gauge under the hood is not nearly as useful as one in the cab.
I'd look at your 818 and bring along a gauge and some fittings and miscellaneous tubing, just in case you need to repair a cut line under the dash. Worst case, use your gauge under the hood before heading out. Best case simple install. Or, maybe a quick repair and go.
R Racing
St. Leonard, MD
Pooked my head up under the dash ( there isnt much room under there ) and it looked to be 1/8 pipe in the gauge and a female fitting on the hose. If its AN its a straight thread.
