Tommy78
- 0
- 6
- Glenfield NY
Which one is more common, bad oil pressure sender or bad oil pressure gauge? When I test drove the truck and also when I drove it home the gauge read 60psi. It would come up right after start up. Yesterday when I started the truck, the gauge did not move. After tapping on the gauge, it went right to 60. I then shut the truck down and could duplicate the same condition without the engine running, turn switch off, gauge drops. Turn it on, gauge doesn't move until you tap it. Im guessing ground issue or junk gauge. Is the ground the gauge case?
