dfanders
- 0
- 0
- Yardville/NJ
I have a 1953 M52 5 Ton semi with a Continental 6602 gas engine. She starts fine, and the oil pressure is good. After running her on the road for approx 20 minutes, the oil pressure begins to drop. over teh course of approx 10 minutes of driving, the pressure gauge drops to 10 PSI and i get a red indicator light. Truck shows no other signs of oil pressure issues( that i can tell) when this happens.
If you let it site for 30 minutes and cool down, when you re-start the oil pressure is back to normal.
I am new to this truck. This had happened with the previous owner , and he suspected a bad oil pressure sender?
If i go the route of replacing the sender , which is the correct part? Should I also replace the g
ge?
I was thinking of taking it to a mechanic who works on 5 tons. I am concerned that when teh oil gets warm , it is leaking past seals & valves. If you know the gasser engine, you know that i can't just look back ato tell if i am blowing the correct color smokle from burinng oil...the gasser engine burns so much gas that it is always blowing cloud of white smoke behind it !!
Thanks,
David
Thoughts?
![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
Thanks,
David
Thoughts?
