Oil Pressure "LOW" ? 6.5L non-turbo
Mogman
10,597
Papalote, TX
My stays solid cold and warm at 30psi.... think the gauges in this rigs are morelike an indicater for high/low not for reading a reale
That is just not normal unless you drive a ford, these do not run the same pressure hot as when cold
Milcommoguy
2,428
Rosamond, CA
My old 86, M998. 6.2L. Clean and strong engine, 54K miles ? that's on the clock. No smoke unless at 6500 hundred feet. Lives at 2600 ft. no smoke down here. 70 degree start 45 PSI, When hot 25 to 35 running down the road. Hot idle 10 to 12. I have military and a mechanical guage, both track +/- OK. I don't worry about it (anymore) It is what it is and the book (TM) says good to go. Hot oil on a 2000 mile change... just pours out thin and black. Blacker than black. Drips for a half and hours. Filter, plug and refill. 15W-40W stenciled on the hood.
Runs like a top. 50 MPH all day long. Hold on for the HI SPEED test run at 60 for two minutes. No issues. Back down to 45 - 50.
Got to baby the beast. Slow and easy. Too damm expensive, CAMO
frauhansen
601
switzerland
No Ford... just watched under the hood... no Sir... no Ford ;-)
It climbes within 5sec up to 30psi and stys there. Even with the old oil from the IROAN it drops down to 20 at german interstate speed of 75 - 85 mph
