ok truck idles, then drives, then acts like it is out of fuel and dies
kcbbqguru
kansas city
put 2 new batteries in, then drive 2 miles to test truck and it acts like it's out of fuel?? dies,
after it sits for 5 minutes it starts right back up, got it home and back in the driveway!
I'm thinking injector pump?? or fuel tank full of crap? any ideas?? Thanks
kcbbqguru
kansas city
brand new fuel filter, truck has been sitting because this problem has been an ongoing issue for last year, will check on full lines next
dmetalmiki
2,026
London England
That problem could be a 'collapsing' fuel line (suction/rubber hose)'
Also known is 'something sucked into the intake line, and drops back when the engine stops.
That append to us on two different Chevy Cheyennes.
cucvrus
9,732
Jonestown Pennsylvania
If it has no leaks. I think the injection pump will get my guess from afar. The injection pump is a magic bullet with many fuel / drivability problems. But that is a guess from afar at best. Also what has been hacked into or just plain neglected? Happy Holidays.
beetleswamp
Honolulu, HI
Clogged fuel sock is a real possibility if it has sat a long time.
You could try hooking up send/return lines to a jerry can and drive it around a to see if it's before vs after IP issue. I also put a clear in-line filter just before IP to watch for bubbles/air leaks.
dependable
187
Tisbury, Massachusetts
Another test for clogged fuel sock: Blow compressed air down fuel line and listen for bubbling in tank, if there is an improvement in performance, you have temporarily unclogged sock and need to clean tank.
