Old thread revived.... NHC 5-ton fuel mileage?
CanonNinja
Houston, Tx
Searched and found a little bit, but figured I'd make a new thread instead of bringing a year+ old thread back from the grave... Looking for fuel mileage/mph that you 800 series guys get and with what tire setup... been semi-swayed away from the 900s and looking into a singled 813 now... I average 8-13mpg in the deuce, just looking for what to expect on the step up. Thanks!
AMGeneral
112
Connelly Springs, NC
Well,at this point I have enough "seat time" in the 816 to answer this,It varies between 4 and 6.6 mpg,depending on load and towed loads.Both trips to haul home the 2 M123's I purchased(about 31K and 22K respectively) the 816 got about 4.3 mpg.Both trips to Aberdeen averaged between 5.6 and 6 mpg.The trip to Ohio with Cabell to pick up his 817 dump averaged out at around 5 mpg(LOTS more hills to pull :driver: ).But this is with a 37,000 lb truck with stock 1100 X 20 duals so a 813 would probably be somewhat better.
Westech
CPL
6,104
206
cow farts, Wisconsin
Well I hope i can come close to my Deuce wtih my 813. I am installing the 14:00's singles and not turning up the fuel or anything. If I got 7+ i would be happy... my deuce got over 10 Im going to mis that , along with burnig anything i could get inthe tank.
CanonNinja
Houston, Tx
I'm with you there... I'm drooling over 813s right now, since I can affectively get on in a a range I can hopefully afford... I've got a few friends that would by my truck today for the price I paid for it originally, which makes it even more hard not to look into the bigger trucks... I wish I had the cash for DMA's truck, but it was out of reach at the time and too far to afford transporting
73m819
314
gainesville, ga.
my 819 (36k lb) get almost 6 mpg on the road, about 4 mpg around town ( a lot of third gear), it has 1200x20s. on the road , it is mostly fifth at 1900 to 2000 rpm doing 60 mph or a bit better, but not on long steap grades
