Oli Pressure Gauge and sending unit
SierraHotel
Haymarket, Virginia
My oil pressure pegs at 60 psi most times. It calms down when idling, but will go back to 60 when it’s on the road. Noting that some Deuces will run at, or above, 60 psi and be fine (or at least according to PS magazine), I purchased a 120 psi gauge. My question is do I have to switch my sending unit as well or since it already registers high, don’t worry about it?
WillWagner
2,698
Monrovia, Ca.
Have you tried a manual gauge yet? You might have the 120 sender in it already. I'd do the gauge first and verify it with a manual gauge, then, if needed, change the sender.
jwaller
19
Columbia, SC
yes the gauge and sender must be swapped at the same time. a lot of deuces peg the 60psi gauge. thats why you have the option of swapping to a 120.
SierraHotel
Haymarket, Virginia
Re: RE: Oli Pressure Gauge and sending unit
If it already reads at the top of the guage, do I need to swap the sender as well? Driver logic would point to the guage would allow the needle to travel to where it needs/wants to be.
jasonjc
289
Gravette Ar.
vtach said:
What if one's duece idles around 15-20, and runs 30-35 while driving?
It's fine the TM say 10psi min at idle and 75psi max at full power.
There is a 60psi sender and a 120psi sender they are not interchagable. You NEED a 60psi gauge AND sender or a 120psi sender and gauge. Or the readings will not be right.
Like said above you may have the 120psi sender all ready and that is the problem.
By this logic you can use a 12volt bulb in a 24volt truck and the bulb will just use the volts it wants.
m16ty
211
Dickson,TN
You may have to scrape some of the od paint off but every sender I've ever seen has had "60" or "120" stamped on the sender.
From wnat I've seen from playing with different gauges and senders the gauge needle works the same on either gauge. They are just numbered different. If you hook a 60 gauge to a 120 sender the gauge needle will still be pointing in the same spot but if the needle says 60 on the 120 gauge it will point to 30 on the 60 gauge. Does this make any sense?
