Olive the 923 project
Pschycopiolt
55
13
Des Moines Iowa
Well this past summer I finally broke the stock transfer case in olive. I decided to pull the trigger and purchase the a55 hett case and this is the progress. So after removing the stock case and finding a hett case I ended up giving 4600 for it. Got it set in and started mocking up mounts I did decide to move it back another 6" plus the original 3" from installing the 16913. Also I have to have the case kicked to the passenger side in order to clear the pto on the bottom of the trans. Relocated the air tank made some longer lines and relocated the abs harness. Currently waiting on the drive line shop shafts should be done in the next day or two. Besides that I just need to make a passenger frame mount to transfer case.
