Armada
- 4
- 0
- Buick City, MI
Slackers.....
Yeah, good free help is hard to get these days.....![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I put in a new drive shaft. I bought a complete balanced shaft with CV joint in place of the upper U-joint. It still has the slip yoke for the NP208. I've had no problems and was able to eliminate the T-case drop.wyliek said:sam did you add s CV joint or did you put a completely new drive shaft in??
i would imagine that you could get an old front cv from a junkyard cheap, if you can just 'add' it to the rear driveshaft.
