- 14,606
- 4,691
- 113
- Buchanan, GA
I picked up a Onan 12.5 generator last night. Basically it's the same as the MEP-003. At lunch I tried starting it but wasn't getting any fuel. I checked the forums and found mention that the center bolt on the hyd. head can stick. I took it apart and found the valve slightly stuck in there. Removed and cleaned it, then worked the lifter up and down several times until I could see that it moved and rotated freely with the engine running. The fuel lift pump was squirting fuel freely through this point. I reinstalled the valve and threaded housing until it bottomed down on the pump. I placed the cap back on and tried spinning the engine over with the lines removed. I didn't get any fuel. I finally tinkered around and realized the valve was staying closed in the center and not feeding pressure to any of the other ports. I backed the threaded portion out a little and placed the cap back onto it. After that, when I rotated the engine all four ports squirted fuel one after another. I reinstalled the lines and left them loose to the injectors. I turned it over a bit until I had fuel dripping from the injector bodies and tightened them down. I can spin the engine over, but it doesn't seem like I'm getting any fuel still. I've sprayed the engine with a little bit of starting fluid and it picks up in RPM's but never runs.
Should I try removing the injectors next and try cleaning them?
The generator has sat for a number of years. The fuel that was drained was very brown and nasty looking. I've filled it up with fresh diesel fuel. But I'm wondering if the injectors are in as bad of shape as the IP was.
