Onan 12.5 Civilian model
Keith_J
1,328
Schertz TX
Awe, shucks! If you have small fingers, you can pull the control lever assembly out without pulling the pump. You need a dental mirror to get it back together. Had the same problem with my 002A. The fuel was like wood stain. I used Pro Shot Copper Solvent IV on that part as it is more aggressive than Berryman B12. And it could be rinsed.
If you can get the pump's gear indexed to the cam gear, timing should be fine as it is only based on the thickness of the shims and button. Not changing any of these means timing is fine. The distributor function has a good "window" but you still need to get it perfect.
5,205
The control lever worked fine, it was the plunger that would stick at the top of the stroke. I know now that the pump internals are spotless at least.
As for the injectors. I just went ahead and purchased a set of new nozzles off ebay for $24.50 each. Hopefully that will get this thing back into shape. I had been talking to a few members here about some unknown takeouts (Thanks Jerry!), but for a little more, why not have rebuilt ones.
Hope to have this thing buttoned up and running before we get any snow/ice storms. It's loaded now on my M105 trailer and the tarp is over it. I'm going to get some flex exhaust pipe to just drape that over the side when it's running.
