- 2,941
- 7,166
- 113
- West greenwich/RI
Looking at the TM, page 41 shows a manual field flashing switch "S", connecting battery voltage to the field flash wires. Is that switch present on your machine and have you tried testing it?
My presumption is that if you have power going to that switch and activating it does not give you temporary voltage ( near normal voltage ) on the lugs, then the gen head probably has an issue.
Regarding no continuity on lug L1, have you tried all positions of the AC select switch? It looks like L1 is only used when in the 3 phase positions, not single phase.
