One-Time No Start due to Oil Pressure
gatorbob
23
Saint Augustine, FL
Hello everyone,
I changed my oil last month and my MEP-803A started right up during Helene. I ran for about 6 hours on 1/4 tank of fuel. No problems.
Today, I topped off my fuel and tried to start up as a test before Hurricane Milton and it didn't start. I had a low oil pressure light. I checked the oil and it's correct. The generator started right up on the second try and I ran it for a few minutes. It may have hesitated just a bit as I was cranking but it started.
I don't believe I held the prime switch very long the first time today but my understanding is that is just to prime the fuel pump. It would be great to know if I am wrong here.
Looking at the TM, checking the fan belt tension is about the only thing I haven't checked in the past month and will do that when I get a break in the rain here shortly.
How concerned should I be given I don't have a lot of time between now and when I might need the generator this evening?
The TM doesn't seem to account for a one-time low oil pressure scenario but I will keep looking.
Edit: batteries are brand new, testing good, on a maintainer. Oil pressure was 50 psi when running.
2Pbfeet
1,519
Mt. Hamilton, CA
Hello everyone,
Good luck with Milton. Stay safe out there.
One does need to let it crank long enough for the oil pressure to stabilize; it is part of the safety system.
My bet is you didn't hold the switch quite long enough,
All the best,
2Pbfeet
