galeo7171
- 1
- 16
- Cumming, Ga
I'm in the process of putting on a new IP. I removed the intake manifold and stuffed the holes with some rags to keep crap from going in there. I didn't think about the actual bolt holes though, and washed out all the crap that has accumulated in the engine valley. I noticed that most of the bolt holes had a little water in them that I was able to blow out with the air compressor. I did notice that one, maybe two of bolt holes did not hold water. Apparently the holes go down into the top of motor. Any idea if that little bit of water going down into the bolt holes is bad?
