- 2,863
- 1,407
- 113
- Czech Republic
I have been looking through TMs and threads quite a lot now, but I am missing something.
According the operating instructions, with everything in neutral put, unlock the winch control lever and put the winch control lever in position Low or High, or even more speed levels in between.
No problem.
The M51Dump Truck has a dual PTO. So if I understand correctly, both the front winch AND the dump hydraulic pump are served by the same PTO and engaged by the same PTO control lever. Lever completely down - PTO drives hydraulic pump, lever completely up drives winch. CORRECT??
What happened with the H and L positions of the winch? Compared with the standard w/w trucks, the completely down position in the M51 is taken by the dump control. In the TMs, I saw the winch procedures always referring to the standard truck, and the dump control referring to the M51. But the positions now overlap, and I did not see that addressed in any operating manual.
Other question. I saw some threads on it, but did anybody ever completed an air-driven shifter for the PTO on an M51A2?
No problem.
