opinions about Deuce 6x6 with HEMTT wheels/395/85R20's
Mud Hugger
Barronett,Wi
The bead locks is the big deal, so he can run lower air preasure to get a large foot print for floatation and such. If you drop tubed tires to low you could blow a bead and or wreck the tube. I do a lot of offroading also but not as extreme.
VPed
315
Clint, TX
Exactly. I aired down this past Sunday and the rim spun inside the tire causing a flat. It only has to spin a half-inch or so to cause issues. I ruined one tire because I did not catch it early and the second will need a new tube. By the way, These trucks run great off-road with flat rear tires. I couldn't tell I had a flat, till I stopped for a refreshment.
LowTech
162
Arizona
We have Mod'd Hemitts w/ GY 395's, on the She Beast. I like the tires, but I think I would go the MRAP route if I did it again. You don't have to cut the rim to add the plate.
I like that thought ;)
