Opinions and Sources for Cab Heaters
joesco
Hampstead, NH
Will be picking up my new deuce in the next couple of weeks and I am already planning for another New England Winter next year.
It has a soft top and no heater. I just completed an exhaustive search and did not come up with much. I have also got a few good suggestions from the current owner. Looking for more opinions please.
What are my options and approximate costs. Thanks folks!!
1,806
NOS heaters are getting scarce. If you find one prepare to spend $500 or more. The other option is fo find an M151 heater or kit and adapt it to the truck. I just bought 2 deuces and sold one to Devilman96. His has an M151 heater in the cab. I know he stayed toasty warm driving back from TN in the sub 30 weather. My truck on the other hand, had nothing so I had to wear a jacket.
joesco
Hampstead, NH
Re: RE: Opinions and Sources for Cab Heaters
Thanks, that was my first choice and I see them for around $100.00. Just wondering how difficult an install it would be. $500 for heat is just not in the budget, paint and tires are on the list also. Just might have to bring the wife along this coming winter!! She would be thrilled! :cry:
1,806
Next time I'm at Mikes, I'll get some pics. It's basically just bolted to the firewall on the pass side. You can see a little bit of it in this pic.
davidkroberts
23
west tennessee
one of the guys on my gama goat yahoo group bought a commercial model available on JC Whitney and converted it. Its a rated 12V blower but a doable project, made for a clean install.
steelandcanvas
85
Southwestern Idaho
Google Midwest Military...They have a heater for M37 for $550...probably work well in a Deuce...Keep looking, I run across them now and then...I bought mine from Frank's Surplus, but I think he's out... Good Luck!
m376x6
Colorado
Heaters
A company by the name of Red Dot has heaters factory made with 2 speed 24 volt motors. They come in a variety of sizes and shapes. They have a link to find nearby distributors and if you get the right one (distributor) you can buy them below retail. Hopefully this link will work.
http://www.rdac.com/
Regards,
Bryan
houdel
9
36
Chase, MI
Not to mention the fact that the OEM Deuce heater pretty much sucks! Depends on how authentic you want to look vs how comfortable you want to be!
joesco
Hampstead, NH
Thanks for the pic, is there an outlet to run a duck to defrost?
cranetruck
75
Meadows of Dan, Virginia
There are actually lots of info on this...
http://steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=16343&highlight=heater+trip
If you want your cab heated before you drive it, consider a fuel burning heater, the only way to go IMHO. The "hot water heater" doesn't get up to speed untill the engine is warmed up and by that time the firewall is hot and it's not needed any longer except for defrosting the windshields (yes, there are ducts for defrosting).
BKubu
1,119
Gaithersburg, MD
I concur with Bjorn. I prefer the fuel burning heaters, but they are very hard to find. The hot water heater kits are sufficient, but you have the problems that Bjorn identified above. Check with HALFTRACK. He sold me a take-out kit that was complete. He says that he takes the heaters out of every truck he gets because he does not need heat down in LA!
saddamsnightmare
80
Abilene, Texas
April 2, 2008.
Dear Joesco:
Look on Saturn Surplus's Site for the Winterization Kit for the M35, complete with winter front it goes for $475.00 or thereabouts. Beats having no heat, no defrost, no nothing in your winters.
Regards,
Kyle F. McGrogan
m16ty
211
Dickson,TN
I've got several pieces and parts of the stock heater but I don't have it all and what I have is in questionable shape. I'm thinking of building my own.You can buy new heater cores on ebay dirt cheap that fit whatever. I am thinking of just buying a core and a blower and building the rest. Shouldn't be that hard.
MilspecKilroy
Fayetteville, Arkansas
Heaters for your deuce
You might also check out www.espar.com They manufacture all sorts of heaters for equipment, off-road trucks, over the road trucks, etc. I checked into their small fuel fired units when spec-ing out an off road rig for an Air Force unit in Alaska. Admittedly, it won't be authentic but if your goal is to stay warm. . .
I just bought my deuce sans heater and someday may consider adding an espar although I'm pretty cold-resistant having spent 9 years in Maine (now in Arkansas) but the girl friend freezes anywhere south of about 75 degrees!
